problem starting hamsphere in linux
2011-12-04 17:25 |
I have 64bit linux mint 10 kde and i tried to install hamphere_3.0.2.8.jar Made the jarfile executable. Then tried to open it with java:
~ $ java hamsphere_3.0.2.8.jar Exception in thread "main" java.lang.NoClassDefFoundError: hamsphere/jar Caused by: java.lang.ClassNotFoundException: hamsphere.jar at java.net.URLClassLoader$1.run(URLClassLoader.java:217) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:205) at java.lang.ClassLoader.loadClass(ClassLoader.java:321) at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294) at java.lang.ClassLoader.loadClass(ClassLoader.java:266) Could not find the main class: hamsphere.jar. Program will exit. Also rightclicking jarfile and selecting open with java didnt open it. $ java -version java version "1.6.0_20" OpenJDK Runtime Environment (IcedTea6 1.9.8) (6b20-1.9.8-0ubuntu1~10.10.1) OpenJDK 64-Bit Server VM (build 19.0-b09, mixed mode) Help would be appreciated. OH2GUF |
Re: problem starting hamsphere in linux
2011-12-15 13:13 |
Moderator Registered: 16 years ago Posts: 160 |
Hi
Just can't get hamsphere to work on ubuntu linux 10.10 call sign 26HS1823 Hi Regarding the above I have now fixed the problem, actions to make the file work are as follows, Right click file, click properties, click permissions, tick make file executable, click open with, click sun java, if this is not installed, install from package manager, Thanks Tony Lawrence callsign 26hs1823 Thank you Tony for your remarks that maybe will help others................ Yes the Jar file needs to be OPENED with JAVA Platform .................... Vic |
2011-12-29 21:41 |
Hello!
I am a new user from St Martin (FWI). I had a problem to launch hamsphere_3.0.2.8.jar from the dock of my Linux (Debian Crunchbang Statler) but not from the folder where hamsphere_3.0.2.8.jar is located. If you have the same problem,
[2] then "open root terminal here" [3] type in the terminal chmod u+rwx hamsphere_3.0.2.8.jar [4] code of the link (in the dock on the desktop): '/home/user/documents/HAM Radio/hamsphere_3.0.2.8.jar' |
2013-07-28 19:51 |
Please try
sudo java -jar hamsphere_3.0.3.2.jar makesure you use the correct filename. OH2GUF Wrote: ------------------------------------------------------- > I have 64bit linux mint 10 kde and i tried to > install hamphere_3.0.2.8.jar Made the jarfile > executable. Then tried to open it with java: > ~ $ java hamsphere_3.0.2.8.jar > Exception in thread "main" > java.lang.NoClassDefFoundError: hamsphere/jar > Caused by: java.lang.ClassNotFoundException: > hamsphere.jar > at > java.net.URLClassLoader$1.run(URLClassLoader.java: > 217) > at > java.security.AccessController.doPrivileged(Native > Method) > at > java.net.URLClassLoader.findClass(URLClassLoader.j > ava:205) > at > java.lang.ClassLoader.loadClass(ClassLoader.java:3 > 21) > at > sun.misc.Launcher$AppClassLoader.loadClass(Launche > r.java:294) > at > java.lang.ClassLoader.loadClass(ClassLoader.java:2 > 66) > Could not find the main class: hamsphere.jar. > Program will exit. > > Also rightclicking jarfile and selecting open > with java didnt open it. > $ java -version > java version "1.6.0_20" > OpenJDK Runtime Environment (IcedTea6 1.9.8) > (6b20-1.9.8-0ubuntu1~10.10.1) > OpenJDK 64-Bit Server VM (build 19.0-b09, mixed > mode) > Help would be appreciated. > OH2GUF |
Problem starting hamsphere in in Ubuntu 20.4
2020-08-10 02:11 |
1. I downloaded HamSphere_3.1.5.jar for MAC and Linux
2. In the Downloads folder I marked the file as 'executable' (at this point I verified jre/jdk is installed > YES! ) 3. In terminal: sudo java -jar HamSphere_3.1.5.jar [password] Exception in thread "main" java.lang.NoClassDefFoundError: org/omg/CORBA/portable/IDLEntity at java.base/java.lang.ClassLoader.defineClass1(Native Method) at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1017) at java.base/java.security.SecureClassLoader.defineClass(SecureClassLoader.java:174) at java.base/jdk.internal.loader.BuiltinClassLoader.defineClass(BuiltinClassLoader.java:800) at java.base/jdk.internal.loader.BuiltinClassLoader.findClassOnClassPathOrNull(BuiltinClassLoader.java:698) at java.base/jdk.internal.loader.BuiltinClassLoader.loadClassOrNull(BuiltinClassLoader.java:621) at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:579) at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522) at com.lindman.hamsphere.UniqueID.getUniqueID(UniqueID.java:13) at com.lindman.hamsphere.UserData. at com.lindman.hamsphere.HamSphere. at com.lindman.hamsphere.HamSphere.main(HamSphere.java:59) Caused by: java.lang.ClassNotFoundException: org.omg.CORBA.portable.IDLEntity at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:581) at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522) ... 13 more Guys this CAN'T be that hard How to correct?? > Kathi N0FKA |
2020-10-18 17:56 |
Same problem, no solution.
Can anyone help? |
