HS and Java on debian Linux
2019-05-04 14:21
is there anyone who can answer to me which JRE version is recommended to use on debian linux (running ubuntu 14 and raspbian 9) ?
I am trying to run hamsphere_3.0.3.2.jar and HamSphere_3.1.5.jar and running into some issues.
Some experience.... to avoid stumbling around.
I have run successfully one of 3x versions on Mac with Java6. But in the meantime industry went on - Java6 is virtually not available, Java7 is not available from producer (oracle) currently only available as alternative (redhat support line), current Java is 8 or 9 but does not seem to be running HS code well.
Java 8 is also available as alternative.
I doubt I can mound Java6 on modern linux (highly discouraged due security issues).
If you have HS working stable on linux - what are you using? (EXACTLY)
thank you in advance.
