Attention, Users with Windows (XP, 7, 8) 64-bit platforms!
2015-04-08 16:08 |
Due to some users who had problems with HamSphere on 64-bit Windows, I wrote this reply as a clue:
13HS1807 Wrote: ------------------------------------------------------- > Hi, > > I can't confirm it on Windows 7 (32). Indeed the > sound stucks sometimes and there is no function > possible, but never the whole program and I think > it's depending on the current server-load. I can > always close it with the normal function ("Power") > and restart it. > > Maybe you can try to install it under the 32-bit > folder and run it in this mode. I'm not sure if it > is a good idea to run HamSphere in 64-bit mode. > > For explanation: There are two different > program-folder in 64-bit versions of Windows. 1. > the "x64" (aka "program" only) and then a "x86" > folder. > The x64 is ONLY for real 64-bit Applications! All > other should be installed in the x86 folder and be > started from that point. > Thats very important to keep Windows (and his > Applications) stable. > x86 means a special virtual sub-system on x64 > Windows platforms (WOW64) and that gives you e.g. > a special memory-management. . Maybe it can help other people as well. :-) 73 and good DX from Jörg :-) JO31ok Bochum / Germany |
Re: Attention, Users with Windows (XP, 7, 8) 64-bit platforms!
2017-11-27 17:41 |
We have been here for the way that can allow us to get the screen recorder for windows 10 here. | |
