Cannot send QSL Card on Mac HS 4.0 Freq Error
2020-02-12 18:21
When I try and send a QSL card to a contact I get an error "make sure you enter in the correct frequency"
The frequency is correct and i have even deleted and re-typed it many times.
I have reset and restarted application many times.
Am I doing something wrong? M0RTK (moderator) and i tried numerous times but it keeps failing.
I did receive his QSL though.
I am using the latest Macintosh version of HS4 downloaded less than a week ago.
Any help or Suggestion is appreciated.
Regards,
Everett-WB9FUW
Re: Cannot send QSL Card on Mac HS 4.0 Freq Error
2020-04-06 12:43
Hi Everett,
sometimes that happens.
Try to set your radio to the SAME frequency again, before you create a logbook entry later on.
The other station will not stay on the same freq. if you try it later - and that point can create a mistake in the system.
So it is very important to use the SAME time (of QSO), that the other operator wrote on his card. Maybe +/- a couple of minutes.
Than type a value for every orther field: name, callsign (of course) and RST. Save the entry (maybe twice, if an error-message appears). Should work now.
