CW Decoder to Text
2015-03-04 23:12
Hello HS Members..
Is there a CW Decoder around or a programe that can be linked to HS3..CW
To convert to Text on RX mode.. Any help most welcome.
Kind Regards.. Fred..26HS9329
Re: CW Decoder to Text
2015-06-23 20:50
Yes, probably the best known is FLDigi, which also does other digital modes. Another good one for windows is Ham Radio Deluxe. You can get the final release of version 5 for free, or there is the new version 6, which is commercial, but has a 30 day trial available. Both of these can be linked digitally to Hamsphere - built in stuff with linux, or a combination of VoiceMeeter and Eltima on windows. For automatic control of the rig, you would need to buy the Interface Adapter from the HS4 shop, which would let you set up a rigCat interface.
VoiceMeeter can be downloaded from http://vb-audio.pagesperso-orange.fr/Voicemeeter/index.htm
and Eltima is at http://www.eltima.com/products/vspdxp
Hope this helps.
73 de Phil C
Phil Culmer
Surgeon Lieutenant (Senior Grade), RMN
HMS Pegasus
QTH IO93sf m7pcc@culmer.org.uk
2015-08-31 08:44
Is there any Instruction Manual for CW Keyer ANT010?
2016-05-29 21:55
CwGet
2016-07-12 08:10
Hampshere Builders.
May you can make easy for radio station`s , What don`t understand CW beeps Da da da di di di dada.
May easy small option Below transceiver Light news ticker.
Some one send CW a decoder convert to Text ( in bode direction TX/RX)
1 TX [ Write cw cq dx cqx what ever ur type ] enter.
2 RX [ txt for qsl 73 51 ] Read ;)
I am wait for this option in future updates
Translator google Dutch / English it like more chinees :-)
2019-04-06 13:22
hi is there a idiots guide for me to read on using a encoder and decoder on hamsphere 4 thank you.
kev 50
2019-05-21 20:59
Trasmettere in CW su Hamsphere 3 non è difficile per decodificare CW in ricezione cosa bisogna fare grazie
2020-06-29 05:59
Estimado amigo
Si compro 1 encoder y 1 decoder es suficiente para trasmitir en CW telegrafia?
Si tengo varias estaciones remotas ,me sirven los 2 aparatos para todas las estaciones o solamente para 1 estacion,como es el caso de las antenas ?
Gracias
Jose
TI2JJP
2020-06-29 06:00
Estimado amigo
Gracias
Jose
TI2JJP
2020-06-29 06:02
Dear Friend
If I buy 1 encoder and 1 decoder is enough to broadcast in CW telegraph?
If I have several remote stations,I am served the 2 devices for all stations or only for 1 station, as is the case of antennas ?
Thank you
Jose
TI2JJP
