Ragchew Net Report for Friday 23rd September 2022
2022-09-23 02:16 |
Moderator Registered: 7 years ago Posts: 326 |
The HamSphere North America 40 Meter/70cm Rag Chew net (NET/NARC) met on Friday 23rd September 2022 on Frequency 434.500 at 01:00 UTC with 11 HamSphere Operators checked in:
NET/NARC Pete (M6INJ UK) Net Controller M7SBC Andrew GB (Netlogger) KD9TQH Bob IN G0JDK Alan GB (Listen mode) VA7FT/VE4 Tim MB K3VIC Vic CA VE3CMT Colin ON 2HS2265 Joe MI 9HS3639 George ON N2JOA John NY KS1K Dave FL Net advisor 11 Check-ins for the Net Question/discussion point from M6INJ was: - What format do you use to construct your CQ call message, how many times do you repeat your call sign, and do you record it on the microphone recorder if you have it and use it? Follow up discussion point From VA7FT/VE$ Tim was: - Follow up discussion point was is there a difference in using CQCQCQ and CQCQCQDX ? This generated a good discussion on both subjects, interesting answers from all. K3VIC ask if there was a way to organise the list in the recorder plug in into groups on a MAC, Tim gave some advice on this subject. Net closed @01:49 UTC. The next session of this net will be on Wednesday September 28th, 2022, at 01:00 UTC on 70CM at 434.500 for the Round Table and/or Discussion. Net Control will be NET/NARC Wayne VE3OHS, and 2HS1189, as Net Logger, do join them. For comments or questions please email: ve3ohs@gmail.co de M6INJ Pete Go Forth and Work Split. |
