Free Map see your contacts at a glance.
2020-06-14 14:58
I hope this is not against the rules please delete if it is.
I use this free map on a site i run and its a good way of keeping track of people you have met i thought therefore it would also work for HamSphere the map is free for the first 1000 markers - http://www.click2map.com
The site seems to be having some issues at the moment so i have switched to google maps https://tinyurl.com/yyskhgka
If you have any questions on how to use it fire away.
As i said above the map is free for the first 1000 markers after that you could simply make a new map with the same title but instead of My HamSphere call it MyHamSphere 2 there is no need to pay!
Re: Free Map see your contacts at a glance.
2020-06-18 14:07
Update -
Since the first post i have found out you can add the contacts QSL card to their marker details i have now updated most of mine
(click on a marker then the photo tab then click on the QSL card image if you want to see a full size version)
Check my map to see how it works - https://tinyurl.com/yyskhgka
2020-07-19 15:18
135 CONTACTS - https://tinyurl.com/yyskhgka
https://hamsphere4and3.freeforums.net/
2021-06-22 09:34
Hi there,
I tried the link via Google but it returned a 404 error.
