A Couple of Noobie Questions
2020-01-13 21:51 |
So as a new Hamsphere user, I have the following questions: I do use both HS4, HS3 AND THE IOS APP. Can I operate CW on Hamsphere 4.0 without purchasing the encoder? I am a straight key person and would love to work CW. On HS3 it is pretty easy (enter text and hit return) but even on HS3 i still do not know how to set sending speed? How does the 6, 2 and 3/4 bands work on HS 4.0 ? Simplex only or are there repeaters? You cannot select an antenna? FM only? Were you not able to select antennas in HS 3? I use the latest Mac versions with a microsoft brand headset/ mic. I can select the headset/mike in my sound preferences and it appears to work but i cannot use the mic in HS4, either PTT or Vox..any items to fix this? Is there a good tutorial on using SSTV and any of the digital modes? Appreciate any and all help. Regards, Everett/WB9FUW |
Re: A Couple of Noobie Questions
2020-04-06 13:00 |
Hi again,
- at HS 4 forum you'll find many CW-threads: http://hs40.hamsphere.com/list.php?54 - yes, there are different repeaters in HS 4 for 2m and 70 cm (all over the world). For VHF/UHF no selectable antennas. - in HS 3 you have only a default antenna (that is the "easy version" of HamSphere) and also no SSB and USB, but a complete DSB-mode. - SSTV and other digital mode topics are also at the HS 4 forum. This one here is primary for HS 3. 73 and good DX from Jörg :-) JO31ok Bochum / Germany |
