QSL cards designed but not appear in LOGBOOK
2019-06-04 04:46 |
Maybe somebody knows why designed from me QSL do not appear online.
I have a problem with already designed templates for QSL. I have 2 designed templates for QSL which are visible in design of QSL option, but the designed QSL cards can not be seen and send in LOGBOOK options. I read every posting for design of QSL, but I did not find similar situation to be mentioned from other users. Please advice me what to do in order to be able to see and send already designed QSL cards to the other stations via LOGBOOK. Regards 9HS6339 Aleaxanadar 9HS6339@torontomail.com |
Re: QSL cards designed but not appear in LOGBOOK
2019-06-04 14:24 |
9HS6339 Wrote:
------------------------------------------------------- > Maybe somebody knows why designed from me QSL do > not appear online. > > I have a problem with already designed templates > for QSL. I have 2 designed templates for QSL which > are visible in design of QSL option, but the > designed QSL cards can not be seen and send in > LOGBOOK options. I read every posting for design > of QSL, but I did not find similar situation to be > mentioned from other users. Please advice me what > to do in order to be able to see and send already > designed QSL cards to the other stations via > LOGBOOK. > > Regards > 9HS6339 > Aleaxanadar > 9HS6339@torontomail.com Hello Hamsphere 3 or 4,0 ??? |
2019-06-08 11:43 |
Hi Alex,
as Geert asked, there are 2 different systems in HamSphere and for both you need different QSL-Editors. This one is for HS 3: http://www.hamsphere.com/qsledit.php And this for HS 4: http://hs40.hamsphere.com/qsledit.php You need to create templates for each system and safe it. After that you can restart your radio (3 or 4) and should see now the new templates in the logbook-section. Make sure using the same Callsign for all! (in case of more than one accounts) 73 and good DX from Jörg :-) JO31ok Bochum / Germany |
2019-06-08 15:43 |
Sent you another PRIVATE HAMSPHERE message........
Call telephone number and I will help you get sorted out . Vic VE3JAR |
