IMPORTANT INFO 2X2 STACKS
The 2x2 stack arrays have been removed from the WebShop since long and we will replace these antennas for all owners. We are coming up on HamSphere 4.0 close down and we are sorry for the delay in handling the 2x2 stack matter. Due to the technical structure and coding of the our Online Shopping system, we can't make historic OSS One Stop Shop TAX returns (VAT) that we use for HamSphere sales. Therefore we need to do this replacement a little differently. This is how we will handle this replacement procedure:
Each 2x2 stack will be replaced by a single 7 Element Quad antenna of the corresponding band. We simply change the Antenna ID and update the price. The price of the single Quad has been and currently is 60 EUR.
Example A: If you bought your 2x2 stack for example at 80 EUR, you will get a 7 Element Quad replacement for the same band at the price of 60 EUR and you will get a HS credit refund of 20 EUR.
Example B: If you bought your 2x2 stack for say 35 EUR you will get a 7 Element Quad replacement for the same band at the price of 35 EUR and no HS Credit refund.
Example C: If you for instance made a zero value transfer of the 2x2 array or purchased the stack at 0 EUR you will get a 7 Element Quad replacement for the same band at zero value which as you know is not possible to sell in Second hand shop.
This procedure will take place 25 Feb 2023.
