Edit QSL Cards
2015-02-22 03:41
Hello
I want to send a QSL cards from a week pass the date of QSL.
My question is how can I edit a call sign and date on QSL card ??
I m using Hamsphere Edit QSL card.
Tks for any wanser.
Re: Edit QSL Cards
2015-02-22 23:33
you can edit this dates in your HamSphere Log-Entry, save it again and then send it via the red "S-Icon" near the callsign/entry.
Once sent a card, you can't change/edit anything on it.
Re: Edit QSL Cards
2015-02-23 15:20
awas nanti di sumprit lho sama pak polisi radio...
Re: Edit QSL Cards
2015-03-28 18:03
Hello HamsPhere friends,
I typed a wrong QTH when I filled the form to have access to HamsPhere. Now the wrong QTH appears on my QSL cards and I would like to change it.
How can I do that?
Thanks for any answer.
14HS3276
Michel
Re: Edit QSL Cards
2015-03-28 23:18
Just go to your Settings -> Change my Profile and change the dates. That's all for HS 3. You can see the QTH in your Profile.
For HS 4 you also have to change your coordinates/locator-grid.
Re: Edit QSL Cards
2015-03-28 23:22
Thanks Jörg. Problem solved!
73 from 14HS3276 - Operator Michel
Clamart - France
Hope to talk to you "on air"!
Re: Edit QSL Cards
2015-03-28 23:27
You're welcome. :-)
Re: Edit QSL Cards
2019-12-14 03:41
Using HS4 I have uploaded my personal QSL card using the QSL Card Editor and saved it. When I view a QSL to send to confirm a contact is shows the default QSL from HS. How do I change that?
Re: Edit QSL Cards
2020-01-03 12:24
Make sure that you edit (and save) the template correct on the HS4 website, not HS3.
Both systems are completely different and you will see only HS4 QSL-Cards in the HS4 version.
