car't talk on ham computer program
2011-06-08 14:48
i have a set of headphones with a mic on now the problem is that the mic dose not work can anyone help me with answer please thanks
Re: car't talk on ham computer program
2011-06-08 17:08
Hello Andy 26HS727
Not being able to know what you proble may be........
Check
1) Soundcard setting........ Microphone level / NOT MUTED??
2) Soundcard devices ........ are set according to your microphone required devices??
3) MAybe your Hamsphere radio does not know you connected microphone.....leave microphone connected ..... turn OFF HamSphere Radio ........... then RE-START Hamsphere Radio ... so it recognizes that a microphone has been added !!! ( initializes)
4) check microphone cable ........ some have a set of volume . on- off switches in the headphone cable ............
Please try these suggested trouble shooting steps.......... If you still have trouble let me know more about your situation.................
Like........ Messages you see in the Cluster ..............What OS are you using ???
Does the needle in the meter wiggle when you talk...............
Do you hold the PTT button in when you talk with the mouse pointer - to keep the red TX light activated.
Good LUck Andy
VE3JAR
2017-10-21 06:17
imo for pc
LyricsBUD
channa mereya
