Easy Way to move audio files from HS4 to HS5 Recorder.
2023-02-17 01:22
Firstly make a copy of your audio files from HS 4 and save off the computer preferably, then press the windows key + r on your keyboard, this will bring up the run box usually down in the left hand corner.
Type in the box %AppData% and press enter, this will bring up the roaming list and in this list is what you need for HS5, copy and paste your audio files into the audio file for HS 5 and close down every thing and you are good to go with your audio files on HS 5.
de M6INJ(Pete)
