Rag Chew Met Report For 13-04-2022
2022-04-13 01:46 |
Moderator Registered: 7 years ago Posts: 326 |
The HamSphere North American Rag Chew Net, met on Wednesday April 13th 2022 on 70CM (434.5) at 01:00 UTC with 13 HamSphere Operators checked in:
NET/NARC – WAYNE (ON) (VE3OHS) NET CONTROL 2HS1189 – RIK (IN) NET LOGGER M6INJ – PETE (GB) ASSISTANT NET CONT & FORUM COORD K3VIC – VIC (CA) VA7FT – TIM (BC) NET CONTROL FRIDAY SESSION G0JDK – ALAN (BG) LISTEN MODE ONLY KS1K – DAVE (FL) NET ADVISOR M7SBC – ANDREW (GB) 2HS1980 – SUNIL (CA) 2HS2265 – JOE (NV) N2JOA – JOHN (NY) KD0ZDU – DON (CO) LISTEN MODE ONLY W7CPT – JIM (WA) ASSISTANT NET CONTROL Thirteen Hamsphere Operators checked in makes for a very busy net. The question for the group came from Andrew M7SBC: There is the LNDX Award for 100 Countries, and you are working toward obtaining that certificate. As an example you have 92 countries on 17 Meters, what would be your procedure(s) for obtaining the remaining number of countries to obtain 100 on 17 meters. What tools etc would you employ to gain the 100th Country Certificate. A North American Rag Chew Net Forum has been added to the Forum pages on HamSphere for all to read. The next session of this net will be on Friday April 15th 2022, at 01:00 UTC on 70CM at 434.500 for the Round Table and/or Discussion. Net Control will be NET/NARC Pete (M6INJ) and 2HS1189 Rik as Net Logger, do join them. For comments or questions please email: ve3ohs@gmail.com de VE3OHS Net Manager Go Forth and Work Split. |
