installation errror???
2011-10-24 19:23
I just found this software. It seems great, but unfortunately after downloading it and installing it with latest java it still does not work. Upon starting the program i have the receiver interface without details, only the reload and the power button is on. Any idea?
thanks
Re: installation errror???
2011-10-24 20:41
Yes. I have an idea.
If you get the interface, the java works fine.
Please start a web browser. Try to reach these servers
http://server1.hamsphere.com
http://server2.hamsphere.com
http://server3.hamsphere.com
The 3.0 is depending on web pages to for the user interface.
You can download the legacy version 2.0.19 and try that.
http://www.hamsphere.com/download
2011-10-25 06:45
thanks for the help. The legacy version solved the problem.
Szabi
2011-10-25 07:03
Hi Szabi. The upcoming 3.0.2.5 version will have some changes that probably will solve the "black screen" scenario.
2012-04-29 13:43
running win xp i to having the same ploblem using v3 black screen scenario but when i run the legacy version no ploblem
2012-05-13 05:41
Error msg. could't load main class. I ran program the other day and made a few contacts but now I get this error. Any ideas ?
David
2012-06-26 17:54
similar problem the software starts and i start hearing things but if i change band the software stops working and freezes have to hard reset the pc to get it back
2012-07-08 19:02
Hello,
I just reinstalled HamSphere after a hard drive recovery. It is not working. When I load it, all I get is the "shell" with the reload and power buttons. The area where the dials and the dialogue on the are located are all blank white. Also when it loads, it goes "ding". I guess this "ding" is happening instead of the program functioning, without any explanation. I do have my mike and headphones plugged in, and Java installed.
2012-07-08 22:17
I installed win 7 32 bit and I no longer have any trouble. We must never play with services delete somethings because we don't know what their for. This has been an interesting trouble.
and I'm so glad it's fixed
David
2012-07-10 22:47
M3AHQ
You said that you get a "black" screen when you run ver. 3.0? I'm getting a white screen. Does your computer make a sound, like a "ding", or other sound suggesting an error on your computer or software?
