Can't download
2009-12-05 00:03 |
Can't download software. The link ( ht tp://www.hamsphere.net/file.php?0,file=2,filename=hamsphere_2_0_14_for_linux_and_mac.jar ) takes me to main page ( ht tp://www.hamsphere.com/index.php ) (splited url to show url instead of actual link). | |
Re: Can't download
2009-12-05 00:06 |
Try the external link: The External Download link
Kelly 10HS100 Wrote: ------------------------------------------------------- > Can't download software. The link ( ht > tp://www.hamsphere.net/file.php?0,file=2,filename= > hamsphere_2_0_14_for_linux_and_mac.jar ) takes me > to main page ( ht tp://www.hamsphere.com/index.php > ) (splited url to show url instead of actual > link). |
Re: Can't download
2009-12-05 00:23 |
External link worked. Thanks
Now I have: "Server is temporarily offline" (I had the same with 2.0.13). I guess a port is blocked for me. I remember somewhere is posted the port number, but can't find it. I will try to ask my network admin to unblock it. |
Re: Can't download
2009-12-05 00:30 |
Yes, that is either firewall or external block of outbound TCP port 8010.
You can try to type ping in the chat and after 10 seconds you should get a pong from the server if the connection is not blocked. |
Re: Can't download
2009-12-05 00:43 |
It's working now, thanks!
Windows version, on virtual machine (vmware fusion) is not working: javax.sound.sampled.LineUnavailableException: line with format PCM_SIGNED 8000.0 Hz, 16 bit, mono, 2 bytes/frame, little-endian not supported. I wonder if it's because java version, or the virtual machine. I'll try in my home, with a real PC. |
Re: Can't download
2009-12-05 00:46 |
Just like Radio Shack says.... You got questions..... We got answers.... hi hi
At least Kelly does. 73 and good luck Jerry - N1TKO |
Re: Can't download
2009-12-05 00:51 |
This sounds very much like the Audio board being in use by something else.
Possibly it could be some file right or device right issue that vmware has with your hardware. My reports say that it works flawlessly in Linux and Mac. I even did a Mac install myself at a friends house and it worked right away. The "LineUnavailableException" sends us a message that it cannot get hold of the audio device in some way. Kelly > > javax.sound.sampled.LineUnavailableException: line > with format PCM_SIGNED 8000.0 Hz, 16 bit, mono, 2 > bytes/frame, little-endian not supported. > > I wonder if it's because java version, or the > virtual machine. I'll try in my home, with a real > PC. |
