Hamsphere 4, Starting transceiver, please wait..
2018-12-26 09:46 |
This morning I want to start Hamsphere 4 as usual, normally I have no problems.. but now I see, Starting receiver, please wait.. but nothing happens! Tried it several times, the same result.
After that I have uninstalled Hamsphere 4, removed all and installed Hamsphere 4 again on my laptop. But still the same problem. So after login, it is said, logged in as 19hs1787 etc.. Then I click on Transceiver and I select then Default transceiver, I click on Ok and Hamsphere 4 says: Starting Tranceiver. Please wait.. Nothing happens, Any advise is welcome.. Here on to my emailaddress: hansstam2012@gmail.com Thanks! |
Re: Hamsphere 4, Starting transceiver, please wait..
2019-03-27 16:05 |
Same Problem. When I try and reload the ap[p it wants me to first open a trial versio,. I am registered till 2020 but cannot use it. | |
2019-03-27 16:10 |
W2JUS Wrote:
------------------------------------------------------- > Same Problem. When I try and reload the ap[p > it wants me to first open a trial versio,. I am > registered till 2020 but cannot use it. Hi. I can see that you are good until 2020. Are you referring to the HamSphere 4.0 PC version or the HamSphere 4.0 Android version? 73 Kelly |
2019-09-03 19:42 |
Hello, I have the same problem, it does not let me start the application in windows, the message that shows me is: "Please add the HamSphere Copyright plate to your rig!" could someone help me solve the problem?
73 |
2019-09-06 09:15 |
Yes. You don't may remove the Copyright plate from the rig. ;-) Normally it's inside per default.
So start the HS 4.0 program and go to "Editor", pick up the Copyright from the left side and move it into the rig. Save and restart the radio. Now it should work well again. 73 and good DX from Jörg :-) JO31ok Bochum / Germany |
