[Ask] Set up new purchased antenna
2015-08-22 08:23
Need your help to activate new antenna...
I purchased 5-element Yagi (17m), rotator and antenna selector by today. I'm done with editor to make rotator and selector visible,
The issue is when I tried to change my default IDC to 5-element Yagi (17m),the light is red still ON..assume the Yagi not active yet.
Currently, I able to use IDC antenna only not the Yagi
Please help guys,
regards
Ronni
115HS292 on HamSphere 4
Re: [Ask] Set up new purchased antenna
2015-08-22 11:45
Hi Ronni,
if you see the different antennas in the selector, they are working. You can activate an antenna by double-click (not only one click). That meight be the reason.
And of course a 17m Yagi only on the 17 meters band, that's for sure.
Otherwise try to restart your HamSphere program. If the issue still exists, write a message to the support.
2015-08-22 17:32
JO31ok ,
Its working now...thank you for input
Ronni
115hs292
2015-08-25 05:14
13HS1807 Wrote:
> Hi Ronni,
> the reason.
> support
I just realized that Yagi for 17m in HS4 only work for 17m only, no harmonic frequensies resonant for other band..:(
Thats the reason why I cannot find my Yagi when working in 10m..:)
Well, my working band is 40-10M..I need directional antenna for these bands .
Can I send back the Yagi to HS store and replace to multiband antenna.I will pay for any additional cost for replacing.
regards
115HS292/ronni
'73
2015-08-25 11:04
You can put it into the second-hand shop and after (re)selling you get this money for your account.
You can buy (maybe also from second hand) e.g. a Cardioid or multi-band or whatever you want.
Of course, a 17 meter antenna can't work on 10 meters (like I wrote above as well):
13HS1807 Wrote:
> And of course a 17m Yagi only on the 17 meters band, that's for sure.<
