[Ask] Set up new purchased antenna
2015-08-22 08:23 |
Need your help to activate new antenna...
I purchased 5-element Yagi (17m), rotator and antenna selector by today. I'm done with editor to make rotator and selector visible, The issue is when I tried to change my default IDC to 5-element Yagi (17m),the light is red still ON..assume the Yagi not active yet. Currently, I able to use IDC antenna only not the Yagi Please help guys, regards Ronni 115HS292 on HamSphere 4 |
Re: [Ask] Set up new purchased antenna
2015-08-22 11:45 |
Hi Ronni,
if you see the different antennas in the selector, they are working. You can activate an antenna by double-click (not only one click). That meight be the reason. And of course a 17m Yagi only on the 17 meters band, that's for sure. Otherwise try to restart your HamSphere program. If the issue still exists, write a message to the support. 73 and good DX from Jörg :-) JO31ok Bochum / Germany |
2015-08-22 17:32 |
JO31ok ,
Its working now...thank you for input Ronni 115hs292 |
2015-08-25 05:14 |
13HS1807 Wrote:
------------------------------------------------------- > Hi Ronni, > > if you see the different antennas in the selector, > they are working. You can activate an antenna by > double-click (not only one click). That meight be > the reason. > And of course a 17m Yagi only on the 17 meters > band, that's for sure. > > Otherwise try to restart your HamSphere program. > If the issue still exists, write a message to the > support ----------------------------------------------------------- I just realized that Yagi for 17m in HS4 only work for 17m only, no harmonic frequensies resonant for other band..:( Thats the reason why I cannot find my Yagi when working in 10m..:) Well, my working band is 40-10M..I need directional antenna for these bands . Can I send back the Yagi to HS store and replace to multiband antenna.I will pay for any additional cost for replacing. regards 115HS292/ronni '73 |
2015-08-25 11:04 |
You can put it into the second-hand shop and after (re)selling you get this money for your account.
You can buy (maybe also from second hand) e.g. a Cardioid or multi-band or whatever you want. Of course, a 17 meter antenna can't work on 10 meters (like I wrote above as well): 13HS1807 Wrote: ------------------------------------------------------- > And of course a 17m Yagi only on the 17 meters band, that's for sure.< . 73 and good DX from Jörg :-) JO31ok Bochum / Germany |
