3.x and 4.x on Ubuntu Linux 14.10 - Audio "Skipping"
2015-06-17 16:08
Firstly, thank you for taking the time to read this post.
I have both current revs of HamSphere setup on my machine (3.x and 4.x) and am able to run each - but with a serious issue that makes it unusable.
I get a frequent audio issue where the received audio "skipps", that is, the audio pulses in and out at around 30Hz with 50% duty cycle (imagine a square wave chopper squelching the audio 30 times per second for 50% of the cycle).
This goes away for anywhere from 1 second to 10 minutes at a time if I change servers or change some settings on the virtual rig (compression for example - basically anything that requires a server reconnect).
I've got a fairly robust connection to the inter-webs if that matters.
Any advice would be greatly appreciated!
Be well,
2HS2832
Re: 3.x and 4.x on Ubuntu Linux 14.10 - Audio "Skipping"
2015-12-13 04:04
Same as above
2015-12-16 23:42
Changed pulse audio to alsa control in hamsphere 3 now to fix same problem in hamsphere 4
