connection
2010-10-31 00:35 |
Bonjour,
Je voudrais savoir ce que veux dire "PIN" lors du loggin a Hamsphere et ou on peut trouver une "PIN" merci Daniel |
Re: connection
2010-10-31 08:07 |
PIN # & PASSWORD are the same thing...................
When you Registered on the FORUM you got a PASSWORD .......... Use that nuber to also to log onto the RADIO as PIN #............. If you forgot ... or wish a NEW PIN#/ Password ............. on the FORUM you can select " FOGOT PASSWORD" and get a NEW ONE .............. 73 Vic |
Re: connection
2011-04-09 02:42 |
My connection seems to be alright BUT: when I click on the "Help" button I get a little blue warning tab that appears in the middle of the screen that says "Application Not found." then it proceads to tell me to go to http://wwwhamsphere/help So I go to this sit and ani't nobody home to help me. I took the puter to my tech and he had it for two days but could not find that anything was wrong.....Whats going gang, can you or someone help. I ani't found anyone that has had this problem.......I use this "Help" button a lot to help with my logs... Help, Help, Help,
Thanks Rich. 2HS324 ( a HAMSPHERE lover ) |
Re: connection
2012-08-07 18:31 |
can,t connect to any qsl instructions , help buttons don,t work,tryed to download several times now,also changed password ten times,nothing seems to work!!!.only radio and transmiter works i can receive and transmit alright. | |
Re: connection
2012-08-07 18:39 |
Dear Lance, I have created a QSL template for you.
Please click here to see your QSL cards Please click here to edit your QSL templates 73 Kelly 5B4AIT |
Re: connection
2013-03-06 15:08 |
A qui de droit un ami essai de se connecter à hamsphere depuis 4 jours sans succès pouvez vous m'indiquer la marche à suivre pour pouvoir télécharger le programme pour 1 an je vous donne ses coordonnées s.v.p. de l'aide serais très appécier .
joce_bin@hotmail.ca mon ancien indicatif était 9HS1423 merci beaucoup Camil Charbonneau 9HS2324 |
