Callsign & Password Login Problem:X
2009-12-07 19:19 |
Hi All,
I have installed Hamsphere on my Laptop using Window7 problem I have is is every time I open the program I have to insert my Callsign & Pin Number I does not save them anybody have a fix. Charlie 9H4CM |
Re: Callsign & Password Login Problem:X
2009-12-07 19:26 |
Hello Charlie.... I run Win 7 and it saves it for me. I may be a setting you have to look at on your laptop.
73 Jerry - N1TKO |
2009-12-07 19:33 |
Hi Charlie.
One other fellow had this problem actually. The remedy was: Remove everything under c:\program files\hamsphere Remove even the directory. Then install it again. It is something about file restrictions/rights in Windows 7. Are you logged in as administrator? With the above steps he managed to get it to work. Anyone else had this problem? 73 Kelly |
2009-12-08 09:25 |
Hi Kelly,
I tried your suggestion and the problem still persists anybody else have any suggestions? Charlie 9H4CM |
2009-12-08 09:38 |
You could try this steps:
go in c:\programs Files\Hamsphere
2 if is there, can you read it opening with notepad or another text editor? 3 If you can read it, is yout callsign in the first row? 4 can you try to modifiy a value then save it? can you save your changes? If I can help you, I'm here... 73 + 51 -- 1HS104 Stefano - IZ3XNJ HamSphere Admin HamSphere Italia Frequenza Monitor 21.380 |
2009-12-09 08:42 |
I have just installed Windows on my main Computer and this also has the same problem willnot save setting tried to do the fix above but could not find the file.
Charlie 9H4CM |
2009-12-09 12:19 |
Problem now Solved | |
2009-12-09 14:29 |
Charles
Great that the log in problem is solved,but are you still having transmitting problems? Jerry - N1TKO |
2009-12-09 15:48 |
Hi Charles.
I am curious. What was your solution? 73 Kelly 9H4CM Wrote: ------------------------------------------------------- > Problem now Solved |
2009-12-10 06:16 |
Just reinstalled the program and Eureka it worked also problem solved with TX removed the usb microphone and just left the camera microphone connected to USB.
Charlie 9H4CM |
2009-12-10 15:23 |
:)-D Beeeee- u-tiful!!
Way to go Charlie! Jerry - N1TKO |
2009-12-12 16:57 |
Hello, i have trouble to log in hamsphere from my job pc, is the program "sensetive" for a firewall?
73 de LA9RKA Sverre |
2009-12-13 14:41 |
Sverre, the HamSphere usess the outbound TCP 8010 port and nothing else.
Regards Kelly |
2010-12-29 17:17 |
5B4AIT Wrote:
------------------------------------------------------- > Hi Charles. > > I am curious. What was your solution? > > 73 > Kelly > > 9H4CM Wrote: > -------------------------------------------------- > ----- > > Problem now Solved |
2010-12-29 17:18 |
I have installed Hamsphere on my PC using Window7 problem I have is is every time I open the program I have to insert my Callsign & Pin Number I does not save them anybody have a fix. | |
2011-01-10 05:56 |
need to know what is in the config file as hamsphere does not write it.
Would like to create it that is if I could see what is in it. |
2011-02-06 14:31 |
Need to find out where I can get the PIN so I can log in for the first time as a guest to see if this is what I will be using in the near future. | |
2011-02-06 15:05 |
Get a new password | |
2011-02-06 15:06 |
Did you read the above notes / messages attached to this thread...............
PIN# and PASSWORD are the same thing....................... You do have a password / pin# to be able to write this message on the HAMSPHERE Forum??? To get the RADIO to work ... you need to : 1) Download hamsphere 2.0 software 2) Install Hamsphere software 3) click on the HamSphere black icon on your Desktop screen 4) enter callsign in the spot on the radio 5) enter pin# / password in the spot on the RADIO.......... You should be able hear radio noise and tune in station audio when clicking on a spike. Keep in mind if you have troubles .... Make sure you have the latest JAVA FILES installed on your computer as well .......... Seeing HAmSPhere is a JAVA APplication !!!!! ================= On HAMSPHERE.com the Forum has a place to enter your email address and it will send you a NEW PIN# / PASSWORD if you forgot the one that was issued to you !!!! [......this password will be good for both FORUM AND RADIO...........] Hope this helps you out !! Vic VE3JAR |
2011-03-16 16:04 |
MAC,DOES NOT SHOW CORRECT FIRST AND LAST LETTERS OF CALL SIGN ???,on log in window | |
2011-03-28 22:39 |
2011-04-01 03:58 |
9H4CM Wrote:
------------------------------------------------------- > Hi All, > I have installed Hamsphere on my Laptop > using Window7 problem I have is is every time I > open the program I have to insert my Callsign & > Pin Number I does not save them anybody have a > fix. > > Charlie 9H4CM run the program as admin - it then has write permission to the programs folder - probably the best fix for this is for the developers to write the config file to program data folder rather then the program files folder. |
2011-05-30 12:20 |
help please | |
2011-06-15 20:36 |
i forgt my password (pin) zygmunt777@shaw.ca | |
2011-06-15 21:55 |
Hi there 9hs128
I activated a new password / pin # for you ...............you should have it in your email already ?? 73 Vic VE3JAR |
2011-10-13 01:27 |
I downloaded hamspher 3.o2.04 and it says password or call sign incorect I use same pass word and call sigh on 2.o works fine, any suggestions? 2hs6356 paul | |
2011-10-13 01:34 |
I downloaded 3.o2.4 I cannot log in because it wont accept my password or call sign I use same password and call sign on 2.0 works fine, any suggestiions? 2hs6356 | |
2011-10-13 12:14 |
Hello Paul 2HS6356
Please try manual typing in the CallSign & PASSWORD into spaces in the login screen. Remember NO space in the front of each of these boxes......... DO NOT use the CUT AND PASTE METHOD........ Sometime when you use this method additional characteristc get included which HAmSphere is not looking foe and causes an ERROR. =========================== Thry that first and let us know if you were successful !!! Thank YOU 73 Vic VE3JAR |
