first time i can't log to Hamsphere
2010-04-19 21:03 |
From 19 april i can't log in Hamsphere because i receive the item message:
It seems like the selected audio capture (Recording) device is not working properly. Please issue the command: /devices and select another device from the list with the command /record x where x is the device number. Please can you help |
Re: first time i can't log to Hamsphere
2010-04-19 21:05 |
Hi!
Did you remove the microphone from the mic input jack? Did you reinstall the audio drivers or any other software related installtiomns regarding audio? What kind of sound board do you have? What devices are listed when you issue the command /devices? 73 Kelly |
2010-04-20 15:58 |
Hi dear Kelly
My problem has been solved. . I formatted my pc and reinstalled the sound card properly. Thank you for your interest in many of om hamsphere. Thank you again for the spirit of work you do for us all. 73 QRO sunny from Casablanca (Morocco) Best regards |
2010-04-29 05:33 |
How do I learn my PIN #? | |
:)oRe: first time i can't log to Hamsphere
2010-09-07 01:55 |
hi I need help please | |
Re: :)oRe: first time i can't log to Hamsphere
2010-09-07 05:57 |
Please help us to help you. Describe you system - CPU, memory, OS etc. Describe what happened and what steps you have taken in an attempt remedy it. Andy KF6PVT/MM0BQV/Broadcaster Hamsphere Forum Moderator |
