Simulation off in the band of 10 meters.
2010-03-24 09:26 |
Is it normal that in the range of 10 meters can disable the simulation of QRM as happens in the range of 6 meters, or is a virtual transceiver failure?
73, Sergio 30HS142 |
Re: Simulation off in the band of 10 meters.
2010-03-24 19:23 |
Is not a failure, it is a feature: is a feature available only on 6 & 10 meters bands, some release ago this feature was available in all the bands... 73 + 51 -- 1HS104 Stefano - IZ3XNJ HamSphere Admin HamSphere Italia Frequenza Monitor 21.380 |
2010-03-24 19:39 |
1HS104 Wrote:
------------------------------------------------------- > Is not a failure, it is a feature: is a feature > available only on 6 & 10 meters bands, some > release ago this feature was available in all the > bands... Thanks Stefano.. The application is a simulation, not a basic voip comms package, and as such simulates 6 & 10 meter FM with the QRN/QRM turned off. As it is impractical, and illegal in most places, to use FM on the HF this option isn't offered. Andy KF6PVT/MM0BQV/Broadcaster Hamsphere Forum Moderator |
2010-03-25 07:26 |
Thank you very much everyone for your responses. I see logic that can perform the operation to remove the QRN, QRM FM as a 6-meter band and the band 2, 70 cm, etc. .. if these exist. But the "hot band" of 10 meters I still do not see sense can be eliminated.
That was all the fantastic work you do every day, and greetings to the entire community. 73, Sergio 30HS142 *and I apologize for my misuse of the English language. |
