Help with transmit please
2010-03-08 09:36 |
I downloaded Hamsphere yesterday and got it up and running on a trial basis,
I would like to know if I can transmit at this point in time, I have tried to do so and the signal meter goes way back to the left and I can not be heard . I am using a headphone and mike combined which works fine on other programs on my pc. I am using Windows xp pro. Thanks for any info. |
Re: Help with transmit please
2010-03-08 11:42 |
When you are in Hamsphere type /devices into the chat widow and hit enter.
This will tell what devices are set up for the audio capture and playback. Select the correct audio input device by typing /record # with # representing the number allocated to the device your mic is plugged into. Let us know how you get on. Andy KF6PVT/MM0BQV/Broadcaster Hamsphere Forum Moderator |
2010-03-08 12:48 |
Ok, lets try and do this right first time lol.
This is what I have. Current playback device 0 Current recording device 0 ---------------- Available playback devices. o:primary sound driver 1:hd audio rear output 2 2:Logitech usb headset 3:java sound audio engine Available recording devices 0:primary sound capture driver 1:hd audio rear input 2:Logitech usb headset ------------------------------------ |
2010-03-08 13:21 |
Try to set /record 2 | |
2010-03-08 15:04 |
Ok, many thanks that seems to do the job | |
Falta de transmissao, nao consigo transmitir., help
2010-05-15 19:06 |
Me Conecto Em Todas Frequencias Mas não transmito, Detalhe, o microfone ESTÁ Perfeito. Ele funciona Outros Bem em rádios. Desde Já muito obrigado Wilson Gonzaga de Assis. wga@connection.com.br Indicativo. PY1WGA. | |
got the carrier but no modulation mike work will on other commucation channels
2010-11-29 01:26 |
only get a carrier on graff but no modulation why and w3ork well on other commucation channel don't know what is wrong | |
2011-01-03 21:05 |
if i type / devices
into thr chat box and enter, all i get is only subsrbers can chat ?? how do i set up record device so i can transmit any help is apprecited regards budd71 |
2011-01-10 12:17 |
These are the differences/Limitations between Subscriber and Trial accounts.
SUBSCRIBER: All functionality enabled. No limitations. TRIAL: # Unable to send chat messages # Unable to use the built in CW keyer # Unable to hide the callsign as "Invisible" # Unable to query user statistics with the /users command # Unable to send private messages # Unable to lookup other users |
Re: got the carrier but no modulation mike work will on other commucation channels
2011-06-29 18:44 |
26hs1650 ther are no geting no modulation when i key up .i have trow the lot. whot is rong i am frustraed nuf .please help me thank you | |
2011-06-29 18:48 |
You can set the source of the microphone with the command /record x where x is the device number. You can easily find out your recording device ID by issuing the command /devices.
First try to type /record 0 in the chat field. Then push the PTT and speak into the mike. Check the ALC meter for a reading. If no signal, try the next device such as /record 1 and repeat. 73 Kelly 5B4AIT |
2012-01-04 11:44 |
26HS847 Wrote:
------------------------------------------------------- > I downloaded Hamsphere yesterday and got it up and > running on a trial basis, > I would like to know if I can transmit at this > point in time, I have tried to do so and the > signal meter goes way back to the left and I can > not be heard . > I am using a headphone and mike combined which > works fine on other programs on my pc. I am using > Windows xp pro. > > Thanks for any info. Hi I have the same problem and cannot transmit. In the "chat box" I get the message chat=for subscribers only" Any assistance will be appreciated. Spikes |
