tecnical troubles
2009-12-05 22:06
In Vista bussines the hamsphere no is good,
Re: tecnical troubles
2009-12-05 22:23
Hello Gabriel.... Right click on the Hamsphere Icon that is on your desktop. After that a menu will drop down. Click on Properties then click on Compatibility.
In the Compatibility tab put a check in the box that says "Run this program in compatibility mode for:"
Then select Windows XP
I will try to post this in Spanish in just a bit.
I hope this works for you.
Jerry - N1TKO
