2.0.19
2010-01-12 20:53 |
WHERE is the new version 2.0.19 cant find to download it isnt under downloads
pob/k8len |
Re: 2.0.19
2010-01-13 00:13 |
Click on "Download the Software" in the main menu. I just did it myself.
73 Jerry - N1TKO |
Re: 2.0.19
2010-01-13 16:09 |
And here is a direct link. It can also be reached from the side menu. | |
Re: 2.0.19
2010-02-19 05:39 |
how come every time that i try to login it says the server is offline | |
Re: 2.0.19
2010-02-19 08:11 |
2HS1073
Please open up outbound TCP port 8010 in your router or firewall. If you get "Server offline" that is the most likely cause. The best thing to check whether it is a locally oriented problem or something caused by the Internet, please Download PingPlotter And trace hamsphere.com You will see the route to the HamSphere server and the ping times as well as packet loss. You will also find if there are any obstacles on the way to the HamSphere server. 73 Kelly |
Re: 2.0.19
2010-07-12 18:04 |
Buenas tardes, tengo poco tiempo usando HAMSPHERE y me parece muy bueno. He hecho muchos contactos. Gracias y saludos
YV3AP |
Re: 2.0.19
2010-07-12 18:06 |
Tengo un problema con la operación de Hamphere, que desearía me puedan asesorar con el, al activar el equipo a travéz del Login, comienzo a recibir normalmente la señal, pero a los pocos segundos se pierde esa señal y se produce un ruido fijo y cuando intento utilizar el PTT, la aguja del decibelimetro se va al final y no refleja ningun tipo de modulación, espero me ayuden a solucionar el poblema. Gracias por su Atención.
YV4DIV fRANK Frank Pinedo yv4div@cantv.net |
Re: 2.0.19
2010-09-16 17:32 |
thanks all that i have had contact with today was very good and good fun for my first time thanks to tomm in weston s mare good to chat and we will again soon 73s (tu) | |
Re: 2.0.19
2011-04-28 00:20 |
Hola soy Roberto Orias de Venezuela, muy bueno esta modalidad muy interesante.
73´ |
