General class frequencies.
2010-01-10 03:44 |
I have installed the radio and it works fine but I can't get it to dial in the right frequencies for the General class range. What am I doing wrong? (sample) 40 meters will not go up to 7.175 the dial stops at 7.099. 80 meters goes to 3.799 and stops there. Appreciate any help so I can join up and use it. Thanks, Bob | |
Re: General class frequencies.
2010-01-10 04:27 |
Hello Bob
The frequencies are just what you see. I understand what you mean about the General Class frequencies but it doesn't matter where or what frequency you operate on, here on Hamsphere. For example, 40 meters goes from 07.001 to 07.099 and that's it. Operate wherever you like. 73 Jerry - N1TKO |
erreor received
2010-01-18 17:22 |
hi dear Jerry N1TKO
73 QRO from Morocco Firstly my best regards to you for accepting my scnd time on Hamsphere. My problem just after my loging on Hamsphere the message item: Debug:TCPConnection_sendBuf:Socket closed The sound is verry noise i dont know what can i do ,please any solution. Tnks Jerry |
2010-01-24 18:00 |
Hi cn8ce
This sounds like a terribly bad Internet connection with a lot of packet loss. I suggest the use of PingPlotter as described in many threads in the forum 73 Kelly |
