Does no work
2010-01-06 22:08 |
I had installed yhe last version on Seven x64. The java applet starts but does not login e does not close the java app. Also i had try to install and run by compatibility mode xp-sp2 and 2000 without solving the problem.
What is the problem? |
Re: Does no work
2010-01-06 23:25 |
Go to www.java.com and get the latest java
73 Kelly 1HS218 Wrote: ------------------------------------------------------- > I had installed yhe last version on Seven x64. The > java applet starts but does not login e does not > close the java app. Also i had try to install and > run by compatibility mode xp-sp2 and 2000 without > solving the problem. > > What is the problem? |
