Transceiver wont load on Hamsphere 4
2015-02-08 21:55 |
Hi,ive downloaded Hamsphere 4 but cannot open Transceiver for some reason!Just get message to say Please Add the Copyright Plate to your Right?But nothing on my right to Add?Ive installed the latest version of Java also im running Windows XP!Thanks for any help... | |
Re: Transceiver wont load on Hamsphere 4
2015-02-09 17:15 |
Can you open the editor? The Plate (with "HamSphere") should be on the main-screen there. Otherwise the transceiver can't start. 73 and good DX from Jörg :-) JO31ok Bochum / Germany |
Transceiver will not work
2015-03-26 17:46 |
The Transceiver is on the screen but it just makes a noise no stations available.
- Allen Kostyk VE6MAN alpe@shaw.ca |
2016-05-22 11:16 |
Transceiver wont load on Hamsphere 4, Windows 10 | |
2016-05-22 12:05 |
Maybe it is a good idea to post such questions into the HS 4 forum:
http://www.hamsphere4.com/list.php?54 73 and good DX from Jörg :-) JO31ok Bochum / Germany |
Re: Transceiver wont load on Hamsphere 3
2016-06-17 04:19 |
I have reg have callsign and password but unable load Hampshire 3 radio interface | |
2017-05-16 02:50 |
I have callsign and password but unable load Hampshire 4 radio interface just wont load transceiver. Editor does come up however. | |
2017-07-30 10:12 |
i have encountered this issue after i have tried to edit the transceiver. hamshere logo must be present and it is. but i'm sure it is something im doing wrong.
workaround this worked for me... copy the default receiver and work with that one NEVER change the default in any way! now for some reason this has happened once or twice...my copies worked but then i will change them again and even the default quits so i just delete the bad copy and default starts working again? hmmmm.... |
2017-10-26 12:48 |
editor or transceiver wouldn't load, what could be the problem? 3.0 will load and works fine | |
2017-10-26 16:10 |
64 bit Windows, or 32?
Some error-messages? 73 and good DX from Jörg :-) JO31ok Bochum / Germany |
2018-03-19 18:49 |
Windows 10 ops system user just wont load; in editor mode it does shows the correct chosen transceiver. When I sign in into the program it shows me as a subscriber when i select transceiver no go. Hamsphere plate is shown in the editor. Weird and no response whatsoever from Hamsphere. Does not make any sense. Reloaded the program after deleting 4.0, downloaded new version and it took all my contacts, QSO's and QSL cards all disappeared . Does anyone have any idea about what is going on? Latest Java also installed just in case.
KD2DI Mark |
