Multiple servers
2011-10-19 22:27 |
HS Users are reminded that HamSphere version 3.0 has expanded to have 3 Servers available.
These Servers can be viewed when you are logged into the Radio. Above YOUR CALLSIGN is an area with SERVER information. A pull down arrow is there for your conveince to select a different server if you so desire. Normally the Server with the lowest PING # is preferred [**ms]. In the case that you have trouble getting connected to a Server.... try another Server so you do not miss out on your enjoyable QSO in progress. 73 Helpful Tip from HAMSPHERE Admin........... |
