Power Setting
2012-08-23 19:31 |
The transceiver power setting is between 0-11.
Here is a power Setting - Watt translation table. 0 = 1 Watt 2 = 10 watts 3 = 30 watts 4 = 50 watts 6 = 100 watts 7 = 300 watts 8 = 800 watts 9 = 1500 watts 11 = 2500 watts The transceiver carrier wave signal injection into the Sphere is simulated using logarithmic functions. This means that the signal propagation is very realistic and comparable with a real shortwave transmitter. Hence using setting 11 constantly will make your signal splatter. Use the power setting with common sense. 73 HamSphere Support |
