CW with fldigi...how i do it
2017-07-30 18:29 |
What you will need
first get the plugin that controls codecs! SABRENT USB-SBCV USB 2.0 External 2.1 Surround Sound Adapter or possibley any other but this is what i used 10.00 2 stereo 3 foot male to male cables 2.00ea at walmart A Four pin splitter to separate speaker and mic jacks on my HP Red laptop 5.00 Here is what to do with the stuff After inserting USB sound card make sure your internal sound mic and speakers sre set to default!!! at least I had to. usb mic in connects to speaker out embedded device usb speaker out connects to mic in embedded device ( your computer or laptop sound card ) ! setup fldigi to use the external usb sound card set all leval adjusments to 0 Set Hamshere 4 to use your computer or laptops Primary Sound driver for audio out and Primary Sound Capture for audio in adjust levels to 0 here are my settings that work for vox enabled ( you can do it manually if you want but when fldigi sends i want the rig vos to activate and turn off after fl is done sending. the usb sound adaptor is set to... mic in level apox 50 gets audio from HS Rig to decode speaker out level aprox 5 sends audio cw or digital modes to HS Rig Embedded sound adaptor settings... mic in gets audo from fldigi 10 Speaker Out 10 On HS Rig Vox delay all the way up double click on vox gain Vox gain aprox 90% MIC 50% POWER OUTPUT 5W default It does not take a lot of power to do CW and DMs most of the time... This is the CORE SETUP I USE...You will not hear any audio out of anything but when you use cw of psk31 or MMSTV slow scan TV you do not need to this should get you in the ball park fine tune settings to achieve ALC Drive in the GREEN i peak about 2 most of the time. 73 Rememer IF one does not succeed.....try again he must...fail you cannot....Yoda |
Re: CW with fldigi...how i do it
2017-08-03 18:23 |
YouTube search KF5IRG or here is the link
https://youtu.be/a8HjGiR3AqQ Hope to work you in one of these wonderful modes for the hobby! 73 |
Re: USING WIN10 WHAT PROG TO USE FOR DIGIMODES
2017-09-05 20:06 |
What program to use for win10 64bit .? | |
2021-10-24 07:07 |
KF5IRG Wrote:
------------------------------------------------------- > YouTube search KF5IRG or here is the link > https://youtu.be/a8HjGiR3AqQ > > Hope to work you in one of these wonderful modes > for the hobby! > 73 Video isn't available on YT 73 de Anton RV3DHC http://www.qrz.com/db/RV3DHC |
2021-10-24 07:44 |
Video is here I found
https://www.youtube.com/watch?v=PgjqAa7f3Rc 73 de Anton RV3DHC http://www.qrz.com/db/RV3DHC |
2021-11-15 01:22 |
I have been interested in working on CW, some local hams have been using a FLDIGI for cw contact.
I have been traying to have an idea about how to plug in the hamshere and the Fldigi, but not luck so far. There a link in Youtube but it is not working anymore. Have an other options to link hamshere and Fldidi or other app? Thanks |
