Do you want to do CW on HamSphere? Well you can!
2013-09-19 19:49
Does CW fascinate you and you would like to do CW on HamSphere but you don't know CW? How about some easy tips for the non user...
1) Make a copy of CW Abbreviations so you know what is being sent to you. Go to: http://www.kent-engineers.com/abbreviations.htm make a
copy of this .
2) You will need a decoder. If you use a iPhone or iPad you can download this app from the App Store. (MorseDecoder) from Hotpaw
Productions. It works great! Android users you too can get a Morse Decoder from the Android App Store. I can't help you with which one to
use.
3) Read the Band Plan. You can use CW on: 30m 10.101 - 10.195 / 80m 3.701 - 3.730 / 160m 1.801 - 1.830
4) Now log on to HamSphere find someone doing CW and open up the Decoder app on your iPhone or iPad set it by your computer speaker.
press the DSB/CW button and now you can type your message to another CW user. Listen to CW being transmitted and use your CW
Abbreviations list to learn what is being said. It won't take you long to learn the jargon and see how to send CW on your very own. It's exciting
to send and receive Morse code on HamSphere. There are many programs on the internet to help you learn CW and you can advance
yourself to learn and practice so you don't need your decoder any more. Enjoy this great function on HamSphere and good CW to you all!
¿El CW que fascina y que le gustaría hacer en CW HamSphere pero no sabes CW? ¿Qué tal unos consejos fáciles para el usuario no ...
1) Haga una copia de CW abreviaturas para que sepa lo que está siendo enviado. Ir a: http://www.kent-engineers.com/abbreviations.htm hacer una
copia de este.
2) Usted necesitará un decodificador. Si utiliza un iPhone o iPad se puede descargar esta aplicación desde la App Store. (MorseDecoder) de Hotpaw
Producciones. Funciona muy bien! Los usuarios de Android también te puede conseguir un decodificador de Morse de la Android App Store. No puedo ayudarte con cuál
utilizar.
3) Lea el Plan de Banda. Usted puede utilizar el CW: 30m 10,101-10,195 / 80m 3,701-3,730 / 160m 1,801-1,830
4) Ahora ingrese a HamSphere encontrar a alguien haciendo CW y abrir la aplicación decodificador en tu iPhone o iPad creado por el altavoz de la computadora.
pulse el botón OSD / CW y ahora usted puede escribir el mensaje a otro usuario CW. Escucha CW se transmite y utilizar el CW
Abreviaturas lista para saber lo que se está diciendo. No le tomará mucho tiempo para aprender la jerga y ver cómo enviar CW en su propio. Es emocionante
para enviar y recibir código Morse en HamSphere. Hay muchos programas en Internet para ayudarle a aprender CW y se puede avanzar
usted mismo para aprender y practicar lo que no es necesario el decodificador más. Disfruta de esta gran función en HamSphere y buena CW a todos!
CW ли очарует вас, и вы хотели бы сделать на CW HamSphere но вы не знаете, CW? Как насчет простых советов для не пользователь ...
1) Сделайте копию Сокращения CW, чтобы вы знали то, что послал к вам. Перейти к: http://www.kent-engineers.com/abbreviations.htm сделать
копию этого.
2) Вам понадобится декодер. Если вы используете iPhone или IPad вы можете скачать это приложение из App Store. (MorseDecoder) от Hotpaw
Productions. Она прекрасно работает! Android-пользователи, которых вы тоже можете получить декодер Морс из магазина Android App. Я не могу помочь вам с какой из них
использовании.
3) Считать План диапазонов. Вы можете использовать на CW: 30 м 10,101 - 10,195 / 80 3,701 - 3,730 / 1,801 160 - 1,830
4) Теперь вход в HamSphere найти кого-то делать CW и открыть декодер приложение на вашем iPhone или IPad установить его на компьютер динамик.
нажмите DSB / CW кнопку и теперь вы можете написать свое сообщение другому пользователю CW. Слушайте CW, передаваемые и использовать ваш CW
Список сокращений, чтобы узнать то, что говорится. Это не займет у Вас много времени, чтобы узнать жаргон и посмотреть, как послать CW на свой собственный. Это интересно
отправлять и получать азбуки Морзе на HamSphere. Есть много программ в Интернете, чтобы помочь вам узнать, CW и вы можете заранее
самостоятельно учиться и на практике, поэтому вам не нужно ваше декодера больше. Наслаждайтесь этой великой функции на HamSphere и хорошие CW вам всем!
Re: Do you want to do CW on HamSphere? Well you can!
2013-10-09 00:43
As a cw operator with over 52 years of cw operation, I can only make one suggestion that may differ from what you commonly hear. If I really wanted to become a competent cw operator, I would avoid using a code reader like it had the plague. You will never become a good cw operator if you don't learn the code by ear. Copying code on a reader just makes you one more appliance operator. Get a cw CD and learn the basic characters, then download and listen to the ARRL code practice sessions and magazine pages. Learn it by ear and you will become an operator, watch it on a code reader and you will become an appliance operator.
2014-04-19 22:06
i discover CW on Hamsphere. why learning Morse in this modern time.
With a simple use you can do morse!
The description from 2HS3433 is good.
He using a Apple Phone app. For the android Phone i use Morse Code Reader.
i try diverend apps but thus is the best.
i use the speaker of the laptop with the microphone of the mobile Phone.
go to the frequentie and put hamsphere on CW and search for a CW station.
start Morse Code Reader en there it is ..youre first reading.
responds by typing tekst and press enter and make youre contacts by CW.
thanks to 2HS3433 for the explaning
see u on 30m 10.120mhz
19hs1795
txt for qso
