How can I Change mycallsign?
2009-12-15 01:19 |
What is the proceedure to change a registered callsign?
jrb |
Re: Change callsign
2009-12-22 16:09 |
Kelly, hello!
At registration I have incorrectly specified the country how I can change the call sign? Yours faithfully. |
Re: Change callsign
2009-12-23 01:58 |
a opção para trocar o caalsign após a assinatura do programa terá que ser resolvido pelo administrador entrando em contacto Kelly Lindman 5B4AIT afim de esclarecer a situação. Agora se ainda não iniciou o período de assinatura do programa o melhor que faz é criar um novo registo de indicativo activar o mesmo e após essa alteração proceder então ao pagamento da assinatura e o problema fica resolvido.
Atenção se criar um novo registo tem de fornecer um endereço de e-mail diferente que qualquer outro que já esteja na base de dados do hamsphere. Espero poder ter ajudado nessa situação. 73 Feliz Natal a todos. >:D< ____________________________________________________________________ the option to change the caalsign after the signing of the program will have to be resolved by the administrator by contacting Kelly Lindman 5B4AIT order to clarify the situation. Now if you have not started the subscription period of the program the best it does is create a new registration code to activate the same after this change and then proceed to pay the subscription and the problem is solved. Attention to create a new registry must provide an e-mail differently than any other that is already in the database HamSphere. I hope to have helped in this situation. 73 Merry Christmas to all. >:D< ___________________________________________________________________ l'option de changer la caalsign après la signature du programme devra être réglée par l'administrateur en communiquant avec Kelly Lindman 5B4AIT afin de clarifier la situation. Maintenant, si vous n'avez pas commencé la période de souscription du programme du mieux qu'il ne fait que créer un nouveau code d'enregistrement pour activer le même après ce changement et ensuite procéder au paiement de l'abonnement et le problème est résolu. Attention, pour créer un nouveau registre doit fournir une adresse e-mail différemment des autres qui sont déjà dans la base de données HamSphere. J'espère avoir contribué à cette situation. 73 Joyeux Noël à tous. >:D< |
Re: Change callsign
2009-12-25 10:02 |
Please email me at accounts@hamsphere.com with the current callsign and the new callsign and I shall attend this.
Regards kelly |
Re: Change callsign
2010-01-05 09:54 |
hi there,now i have the program working,and a great program it is,how can i change my callsighn from 26HS273 to G6PKS,hope this can be done,cheers brian. | |
Re: Change callsign
2010-01-05 15:03 |
Hello Brian
Email: admin@hamsphere.com and request a call sign change. Jerry - N1TKO |
Re: Change callsign
2010-01-10 17:19 |
I want to change my callsign
My real callsign TB2CSZ Would you please change? |
Re: Change callsign
2010-01-10 17:42 |
Hello Nejdet,
Please email admin@hamsphere.com to have your Ham Radio callsign verified and then ask to have it changed. 73 Jerry - N1TKO |
Re: How can I Change mycallsign?
2010-08-03 03:54 |
how do i change my caiisign? |
2010-08-03 03:55 |
how do i change my callsine | |
2010-08-03 03:58 |
MY CALLSIGN IS M3 PFK | |
2010-08-03 05:33 |
Please read the post above.. Andy KF6PVT/MM0BQV/Broadcaster Hamsphere Forum Moderator |
2010-11-12 03:05 |
change from 2hs5407 to kc9lal | |
call sign
2010-11-12 03:18 |
to my call kc9lal | |
Re: call sign
2010-11-12 03:46 |
change call sign to kc9lal my e-mail kc9lal@gmail.com. | |
Re: Can you help me to change callsign
2011-04-19 05:11 |
No more than 2 month ago I got my technician amateur callsign and if it's possible to change it, please letme know how or wath need I do taht's KJ6NHH KJ6NHH |
2011-04-19 12:40 |
Hello 2HS778
I sent you a Private Message with information about callsign changes ...... Look forward in receiving further information from you and then completing the changes you requested .... 73 Vic VE3JAR |
2014-08-24 01:24 |
As of today I subscribed to HS and would like to change my call sign originally asigned as 69HS311 in the trial version, to my official call sign of "TI2BLL" amateur license class A, obtained in early 90's.
Thank you very much and 73s Luis Barrantes Heredia, Costa Rica |
2016-06-07 17:24 |
Hi!
My real callsign is S21ON. Would you please change it? my email: shantoastro@gmail.com |
