TX Audio error
2010-04-30 20:18 |
here is what i get
it seems lik the selected audio capture (recording) device is not working anybody had this error msg. and how do u fix it........................tnx |
Re: TX Audio error
2010-04-30 21:06 |
Hello Robert KS4JC
If you are refering to the Microphone testing freq 50.12345 ..... not responding with a Recording & PLayback.......... I would just suggest giving it another try .......... I had the same thing happen a few days back ...........nothing happened ?? But a while later it did work again Robert........... ======================= If this was not what you referred to......... sorry for not understanding !! Please reply with some more information and I am sure some-one will be able to help you out ....... Welcome ...... have fun on HamSphere 73 Vic VE3JAR |
TX Audio error
2010-05-29 06:15 |
Hi Fellows
When I try to operate the software that is the error message i get Welcome to HamSphere Client ver: 2.0.19 Skin ver: Standard 2.0.7 Debug:TX Audio error:line with format PCM_SIGNED 8000.0 Hz, 16 bit, mono, 2 bytes/frame, little-endian not supported. What Is the problem and how i fix it ? I use windows 2000 and the Audio is AC97 Thanks For Any Help Ronen - 4Z4ZQ http://www.ronen.org |
Re: TX Audio error
2010-05-29 06:57 |
Hi Ronen.
Your sound card / driver does not support 8 kHz sampling rate. It is common that older drivers and soundcards may have this limitation. The lowest sample rate supported by older drivers and sound cards is 11025 hz. I suspect the Win2K driver. Win2k is a very old op system, over 10 years old. I suggest you upgrade your operating system to WinXP or Win7. Windows 7 comes with most drivers. Regards Kelly |
