playback devices
2010-04-21 21:15 |
hi, is there a way to lock in your devices ie. /play 1 - record 3 . these are for my microsoft headset.i recently upgraded from windows xp to windows 7, never had this problem before. at the moment you have to change settings each time you switch on hamsphere. many tks scott 73's | |
Re: playback devices
2010-04-21 21:48 |
Hi Scott.
These settings should be automatically saved in the hs20.cfg file. I bet you also have to type callsign and PIN each time you start the radio? Reports are saying that the \program files\hamsphere directory in Windows Vista and Windows 7 needs to be writable by the application. There are a few tricks to accomplish this: 1. Use HamSphere as Administrator 2. Right click on the HamSphere directory and check the file rights. Change to read/write. 3. Delete the hs20.cfg if it is in the HamSphere directory and restart the HS app. Let me know how it goes. 73 Kelly |
2010-04-22 00:54 |
kelly, sorted , not sure how, but your suggestions sure worked. many tks. talk soon | |
