Hamsphere and Linux
2010-02-19 21:09
Hello!
I want to install Hamsphere on my Linux-Desktop (Mandriva 2010). How can i install it. I have downloaded but i don t know how to do.
73 de 13hs181, Michael
Re: Hamsphere and Linux
2010-02-20 04:52
first off you need java and java vm. right click on the hamsphere package and select run in java vm
2010-02-20 21:39
Sorry, Jeremy, it dont works - i have no enough nowhow für linux - i must run it under virtual box and xp - but i dont want to work with xp, because to many virus-mails and and....
I have no idea, what can i do.
73 de 13HS181, Michael
2010-04-11 11:34
13HS181,
What version of Linux are you using? I run Ubuntu (Karmic) and have installed Java and HamSphere runs flawlessly. I will be able to assist but can you please advise what version of Linux you use?
Rgds
Franck
2010-05-04 08:15
Hello Frank!
Now i have suse linux 11.2 installed. And Java Sun. But it brings an error-message:
missing fieldexeption jnlp
I dont know what can i do.
2010-05-08 11:46
Hello,
I need some help also :
Iwhen i want run Hamshere, i have that error message :
The file '/home/jean-yves/Bureau/hamsphere_2.0.19_for_linux_and_mac.jar' is not marked as executable. If this was downloaded or copied form an untrusted source, it may be dangerous to run. For more details, read about the executable bit.
My version is Ubuntu 10.04.
An idea ?
Thank's
2010-05-13 01:49
To F4JLC:
Hamsphere needs to run under Java, and needs a bit of help to work under Linux. I made a shell script to run my Hamsphere, which is in the directory /home/lex/Hamsphere.
#!/bin/sh
myname="$0"
run_dir="$(dirname ${myname})"
cd "${run_dir}"
java -jar hamsphere_current.jar
I call that script 'run.sh'. You can create it with gedit or if you're happy with the commandline, 'vi' or 'nano'. Save it to the directory with your hamsphere .jar in it, and set it as executable. If you're using GNOME, this means going to the Places menu and choosing 'Home Folder', then double-clicking 'Hamsphere', right-clicking on 'run.sh', selecting the Permissions tab and enabling 'Allow executing file as a program' next to 'Execute'.
On my system, 'hamsphere_current.jar' is a symbolic link to the current hamsphere .jar - you can use 'hamsphere_2.0.19_for_linux_and_mac.jar' instead, but you'll need to edit the script when updating Hamsphere.
Once the script is in place, you can add a launcher for it by right-clicking in a GNOME panel, choosing 'Add To Panel' and selecting 'Custom Application Launcher'. Fill in the following values (in bold), substituting the name of your launch script under the 'Command' field:
Type: Application
Command: /home/lex/Hamsphere/run.sh
Comment: Run Hamsphere
My Java version is Sun Java 6 (sun-java6-jre, sun-java6-bin) on Ubuntu 10.04 (Lucid Lynx) - I found that only Sun Java will work.
Cheers
Lex.
2010-05-13 02:44
Ok many thank's Lex.
I found the command:
"java -jar /home/jean-yves/Bureau/hamsphere_2.0.19_for_linux_and_mac.jar"
on another topic last week.
I think your aswer can help another user.
Cherrio bye
73's de F4JLC
2012-04-21 19:54
i have got java but i still get loged out i would be grateful if i could have extra days because i have got 1 trial date left 26hs3122
2012-04-29 22:26
That sounds like an accounts issue - try sending the admin a message.
2017-02-22 03:54
HI ,, I am trying to install HS3 on my unbuntu system,which is 11.04.. but I get the following error..
Archive: /home/graeme/Desktop/HamSphere_3.0.3.2_setup.exe
[/home/graeme/Desktop/HamSphere_3.0.3.2_setup.exe]
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
zipinfo: cannot find zipfile directory in one of /home/graeme/Desktop/HamSphere_3.0.3.2_setup.exe or
/home/graeme/Desktop/HamSphere_3.0.3.2_setup.exe.zip, and cannot find /home/graeme/Desktop/HamSphere_3.0.3.2_setup.exe.ZIP, period.
can anyone help.. ?
Thanks In Advance..
de Graeme VK7KT
2017-02-22 04:20
just tried to install using Wine.. but it has come up with this
The file '/home/graeme/Desktop/HamSphere_3.exe' is not marked as executable. If this was downloaded or copied from an untrusted source, it may be dangerous to run. For more details, read about the executable bit.
what could be causing this..?
2017-02-22 12:35
Could you try another ZIP/Unzip program for linux? E.g. "7Zip" or something like that.
And on Linux it needs rights for execution. (e.g. (0)777 for full rights include "owner" and "others")
2017-03-01 09:17
You've downloaded the Windows executable. For Linux or Mac, you need the jar file instead.
http://www.hamsphere.com/dl/hamsphere_3.0.3.2.jar
Once downloaded, I suggest moving this to a directory where it's going to be safe - i.e. not accidentally deleted - and then run it with
java -jar hamsphere_3.0.3.2.jar
If all is well, the HamSphere window should open. If not, check that you have Java installed. Check your DISPLAY environment variable. You can create a launcher to start HamSphere without having to open a terminal.
I hope that this helps!
Lex
