Login
2010-02-05 18:18 |
I've got Hamsphere to load and the chat screen asks me to complete the devices listing - I've changed the soundcard for play back but don't have a record device (reading the notes I don't seem to need to set this up). I have completed the callsign and PIN boxes and clicked on the login button but nothing happens. I have disabled my firewall. Help please as my "free" days use is fast running ou!.
Richard |
Re: Login
2010-02-05 18:25 |
Moderator Registered: 16 years ago Posts: 437 |
Hello Richard
Try downloading the latest version of Java.... HERE Please post back here to let me know if this worked for you. 73 Jerry - N1TKO |
Re: Login
2010-02-05 19:21 |
Thanks for the prompt response, Jerry. I had Java Version 6 Update 18 installed which seems to be the most recent.
Regards, Richard |
Re: Login
2010-02-06 01:55 |
Did it work?
Jerry |
Re: Login
2010-02-06 10:52 |
No but I have just run Hamsphere on an Acer Aspire One (Linpus Linux) netbook. Loaded immediately and works without any adjustment - great. It must be the security settings (I'm using Kaspersky) on my PC causing the problem so I'll use the netbook.
Many thanks for the help (judging by your callsign appearing all over the place you must spend your life on this). Regards Richard |
Re: Login
2010-02-06 15:53 |
Hi Richard
HA!!! Well not my life but a great deal of time. I'm happy you are on with your other computer. I'll catch you on the bands sometime. Take care and best 73 Jerry - N1TKO |
Re: Login
2010-02-10 20:58 |
| a little help here... logging in.. device set to play back. set up on laptop. i don't have a recording device. i do have java recent update. i am obviously doing something wrong | |
Re: Login
2010-02-10 22:51 |
hello John
Check out THIS page and let me know if it helps you out. Also, first thing.... make sure you have a mic plugged in or some type of built in mic on the laptop. If you have neither, that could be why you are getting that message. Let me know how you do. Jerry - N1TKO |
Re: Login
2010-06-05 05:17 |
| Where do I get my PIN # to log in? | |
Re: Login
2010-06-08 22:34 |
Re: Login
2010-06-08 22:41 |
Moderator Registered: 17 years ago Posts: 160 |
PIN # & PASSWORD are the same thing................
Log onto RADIO your Callsign and the SAME PIN# / Password you used to log on to the HAMSPHERE FORUM to create this message..............When you registered. If you want another PIN # / PAssword there is a menu selectioncalled "FORGOT PASSWRD" enter Email address and a new one will be sent to you into EMAIL program ............. Vic Ve3JAR |
Re: Login f1p4
2023-07-23 00:58 |
WP4KUW Wrote:
------------------------------------------------------- > Where do I get my PIN # to log in? |
