Setting Up the Software For Linux Ubuntu 11212
2010-02-02 21:12
How do i install HamSphere 2.0.19 for linux Ubuntu 9.10- the karmic Koala
Re: Setting Up the Software For Linux Ubuntu 11212
2010-02-02 22:13
Hello Leroy
I'm sure there are Linux users on here that can help you.... I hope. I just took Ubuntu off a machine I had because i was having such a hard time installing anything...
Sorry i can't help you. It can be done... I do know that.
Jerry - N1TKO
2010-02-03 03:22
Hi guys,
All I did was download the package to my desktop and then right clicked and ran with java and it works just fine. I've been running Ubuntu along time as a duel boot system and love it.
2010-02-22 02:21
Jeremy,
Have you tried it with Xubuntu 9.10?
Bill
2010-02-22 02:33
Hi Bill,
No I haven't tried HS with Xubuntu yet but I would think it would run just fine since it ran great with Ubuntu 8.04 and 9.04. Kubuntu was a little sluggish due to all the eye candy.
2010-03-01 00:13
Hi Guys,
Like Jeremy said,just download it ,then Java. I just signed on for the first time,running Ubuntu 9.10. Linux is a great O.S, when you get used to it's great !!!
Rob -n7erd
2010-03-23 01:32
Using Fedora 12 distro, all I did after downloading was open a terminal window and ran "java -jar" (no quotes) followed by the path to filename hamsphere_2.0.19_for_linux_and_mac.jar and it loaded right up no problem.
Bob--K8RYA
2010-05-04 08:21
Hello!
I use suse linux 11.2. I downloaded Java Sun. But it dont want to start. Im new in linux, so i dont know, what can i do.
73 de 13HS181, Michael
2010-08-09 00:06
any hints for ubuntu 10.04? i downloaded hs and java but cant seem to open the package with out it unpacking.
2010-08-14 20:17
Hi KF5CJO,
you have to start the downloaded *.jar file only, even in your terminal. Unpacking is unnecessary.
73, Andras
2010-09-18 17:21
i tested it with ubuntu 10.04 and kde 4.5.1 and work with out error but you need java install before you can use it
9hs714
2010-09-27 20:29
kbq2dj,
I downloaded to desktop, used open with OpenJDK Java, ***after changing the file properties*** under Permissions to allow executable.
I'm running lucid on an old Sony Vaio and it's working like a champ!
