Setting Up the Software For Linux Ubuntu 11212
2010-02-02 21:12 |
How do i install HamSphere 2.0.19 for linux Ubuntu 9.10- the karmic Koala | |
Re: Setting Up the Software For Linux Ubuntu 11212
2010-02-02 22:13 |
Hello Leroy
I'm sure there are Linux users on here that can help you.... I hope. I just took Ubuntu off a machine I had because i was having such a hard time installing anything... Sorry i can't help you. It can be done... I do know that. 73 Jerry - N1TKO |
2010-02-03 03:22 |
Moderator |
Hi guys,
All I did was download the package to my desktop and then right clicked and ran with java and it works just fine. I've been running Ubuntu along time as a duel boot system and love it. |
2010-02-22 02:21 |
Jeremy,
Have you tried it with Xubuntu 9.10? Bill |
2010-02-22 02:33 |
Hi Bill,
No I haven't tried HS with Xubuntu yet but I would think it would run just fine since it ran great with Ubuntu 8.04 and 9.04. Kubuntu was a little sluggish due to all the eye candy. |
2010-03-01 00:13 |
Hi Guys,
Like Jeremy said,just download it ,then Java. I just signed on for the first time,running Ubuntu 9.10. Linux is a great O.S, when you get used to it's great !!! Rob -n7erd |
2010-03-23 01:32 |
Using Fedora 12 distro, all I did after downloading was open a terminal window and ran "java -jar" (no quotes) followed by the path to filename hamsphere_2.0.19_for_linux_and_mac.jar and it loaded right up no problem.
Bob--K8RYA |
2010-05-04 08:21 |
Hello!
I use suse linux 11.2. I downloaded Java Sun. But it dont want to start. Im new in linux, so i dont know, what can i do. 73 de 13HS181, Michael |
2010-08-09 00:06 |
any hints for ubuntu 10.04? i downloaded hs and java but cant seem to open the package with out it unpacking. | |
2010-08-14 20:17 |
Hi KF5CJO,
you have to start the downloaded *.jar file only, even in your terminal. Unpacking is unnecessary. 73, Andras |
2010-09-18 17:21 |
i tested it with ubuntu 10.04 and kde 4.5.1 and work with out error but you need java install before you can use it
73 9hs714 |
2010-09-27 20:29 |
kbq2dj,
I downloaded to desktop, used open with OpenJDK Java, ***after changing the file properties*** under Permissions to allow executable. I'm running lucid on an old Sony Vaio and it's working like a champ! |
