Send your Pictures and Photo's to each other while on Hamsphere
2015-02-17 17:47 |
Want to exchange your pictures with each other while you are on Hamsphere ?. Well you can with a ham programme called INTERACE.
this software was released by Martin Emmerson G3OQD some years ago. You can download it from http://www.g4xgt.co.uk/interace-sstv.htm. The software can be used by licenced Hams and shortwave listeners. It connects to a server which shows who is online. There are a few things you have to be careful with when setting it up. Open the set up box. If you licenced put your callsign in the callsign box. And your location in the information box. Hamsphere user callsigns put "SWL" in the callsign box. Then put your Hamsphere call number in the Information box. Select the server from the dropdown box and select "voyager.mcc.ac.uk" and select port 80. make sure your windows firewall is open to this software. To exchange pictures just click on the users callsign or the SWL against their callsign and click send.Load a picture into one of your memories first. You must also make certain that your router is set to port forwarding allowing ports 27222 and 27223 to be open.Setting these ports is a one time thing and you will not need to touch again. Please consult your routers manual on this subject and how to open ports. A bit more help can be found on G4XGT's site regarding this but all routers are not the same so check it out in your manual.. Or check out your ISP's help pages if they supplied the router. Sorry I cant help any more on the router setup. Hope you find this helpful... If you get it working Enjoy. |
