2500 Watts!???
2014-09-03 22:10
Hello Hamspherians,
The "Features" tab above says the transmitter is 1 to 2500 watts. Mine is 100 watts max...no amplifier is listed as a plug in. What am I missing?
73 de Steve
Re: 2500 Watts!???
2014-09-06 12:56
That's only in HamSphere 3, because there are no plugins. That's not real, of course. No real transmitter has a 2500 W amplifier inside.
On HS 4 the transmitter has only 100 Watts maximum, like in the real world. Later on you should can buy some amplifiers from the shop.
And on HS 4 it is possible to work (for example on 40 meters) with only 5 watts under good propagations, which is also realistic.
Normally you don't need 2.500 watts with good antennas, I make a QSO between Germany and USA/Canada with only 100 watts! Not most of the time, but very often. For example on 20 or 15 meters, which are very good DX-bands.
In HS 3 it is not "real", because this program is a little bit more like Skype and so on.
