HS 3.0 Update
2011-05-18 15:23 |
Admin Registered: 16 years ago Posts: 1,061 |
Dear users.
HamSphere 3.0 is still undergoing inhouse testing and will be available for beta testing soon. The new release is aiming for reliability in both receive and transmit. The new system is utilizing multi servers and we are testing with so called "Virtual Cloud" servers in different parts of the world. Here is a quick screenshot of the new release coming up soon. The biggest difference is the login screen that is fully HTML driven. This calls for dynamic configuration and multi language support. Please note the server selector. Servers can either be automatically choosen on best ping times or manually overridden. Accounts are as from 3.0 created and maintained in the client. Also the subscriptions are done via the client. ![]() This is the current list of features / enhancements of the HamSphere 3.0 software Transceiver. ====================================================================== Cleaned up Server messages Reworked Warning messages in Client. Added dynamic text support. Slightly reworked Skin. Subscription support in client. Improved audio help in client. Improved user Authentication New color codes in the cluster indicating user level. More F1-F12 Key functionality by using ALT key. Reorganisation of the F-Keys. Programmable F-Keys Each user can download an automatic user log from www.hamsphere.com with QSO info. VOX operation Improved and reworked Audio Test repeater. Consistant UTC time usage throughout the application. Cluster frequency inconsistancy fix. Improved cluster scrolling and reading. External CW input, true carrier keying. External control API (Via tcp/http) for interfacing other systems. Reworked Skin transparency. Codec off mode. Ability to use full 4 kHz non coded 128kbit bandwidth for proper SSTV and Digital transmisions. Mouse over identification in FFT. Improved microphone level AGC. Added digital S-meter readout. Reworked code for server performace. Improved realism, reworked S/N parameters. Applied Grid square propagation parameters. Hidden administrator audio communication channel (for admin maintenance purposes) |
