Do you have the correct power settings for contests?
2013-10-27 03:27
Do you have the correct power settings for contests? If you don't, your contact will not be counted. Read this important information.
The transceiver power setting is between 0-11.
Here is a power Setting - Watt translation table.
0 = 1 Watt
2 = 10 watts
3 = 30 watts
4 = 50 watts
6 = 100 watts
7 = 300 watts
8 = 800 watts
9 = 1500 watts
11 = 2500 watts
The transceiver carrier wave signal injection into the Sphere is simulated using logarithmic functions. This means that the signal propagation is
very realistic and comparable with a real shortwave transmitter. Hence using setting 11 constantly will make your signal splatter.
Use the power setting with common sense.
Paul
