Edit QSL Cards
2015-02-22 03:41 |
Hello
I want to send a QSL cards from a week pass the date of QSL. My question is how can I edit a call sign and date on QSL card ?? I m using Hamsphere Edit QSL card. Tks for any wanser. |
Re: Edit QSL Cards
2015-02-22 23:33 |
you can edit this dates in your HamSphere Log-Entry, save it again and then send it via the red "S-Icon" near the callsign/entry. Once sent a card, you can't change/edit anything on it. 73 and good DX from Jörg :-) JO31ok Bochum / Germany |
Re: Edit QSL Cards
2015-02-23 15:20 |
awas nanti di sumprit lho sama pak polisi radio... | |
Re: Edit QSL Cards
2015-03-28 18:03 |
Hello HamsPhere friends,
I typed a wrong QTH when I filled the form to have access to HamsPhere. Now the wrong QTH appears on my QSL cards and I would like to change it. How can I do that? Thanks for any answer. 14HS3276 Michel |
Re: Edit QSL Cards
2015-03-28 23:18 |
Just go to your Settings -> Change my Profile and change the dates. That's all for HS 3. You can see the QTH in your Profile.
For HS 4 you also have to change your coordinates/locator-grid. 73 and good DX from Jörg :-) JO31ok Bochum / Germany |
Re: Edit QSL Cards
2015-03-28 23:22 |
Thanks Jörg. Problem solved!
73 from 14HS3276 - Operator Michel Clamart - France Hope to talk to you "on air"! |
Re: Edit QSL Cards
2015-03-28 23:27 |
You're welcome. :-) 73 and good DX from Jörg :-) JO31ok Bochum / Germany |
Re: Edit QSL Cards
2019-12-14 03:41 |
Using HS4 I have uploaded my personal QSL card using the QSL Card Editor and saved it. When I view a QSL to send to confirm a contact is shows the default QSL from HS. How do I change that? | |
Re: Edit QSL Cards
2020-01-03 12:24 |
Make sure that you edit (and save) the template correct on the HS4 website, not HS3.
Both systems are completely different and you will see only HS4 QSL-Cards in the HS4 version. 73 and good DX from Jörg :-) JO31ok Bochum / Germany |
